Rage tokens and Psi / Vig 0
02-04-2013, 04:09 AM
Hey,
just a couple of questions: Can a model get a rage token if it has psi or vig of 1 or 0? And what happens if you have a vig of 1 or 0 and get attacked? Does the enemy automatically get as much successes as he has cbt? Can you get negative stats? Thanks
02-08-2013, 03:48 AM
RE: Rage tokens and Psi / Vig 0
Everything you need to solve these riddles is in the rulebook
![]() In short, yes you can have negative stats, but for gaming purposes, any value below 0 is equal to 0. And yes, if you hit someone or something with a VIG 0, all dice are successfull. Also note that if a fighter with a characterstic of 0 must roll under this stat, it is automatically a failure (e.g.: no successes at all).
02-08-2013, 09:28 AM
But that don't anwers if someone can get more rage tokens if he has already 0 PSI/VIG.
Found that part about the negative values myself. Should have said that ![]() I'm just delivering questions from a german forum ![]() Greetings |
02-08-2013, 09:39 PM
Yes, you can get Rage tokens even if it brings your PSI and/or VIG stat below 0
02-09-2013, 12:45 AM
Thanks for answering
User(s) browsing this thread: 2 Guest(s)
![[Image: subnorm_wide.jpg]](http://cdn-i.dmdentertainment.com/funpages/cms_content/16831/subnorm_wide.jpg)
