The Hord
04-23-2012, 08:09 PM
(This post was last modified: 04-25-2012 08:46 PM by Berf.)
The Hord
For those who couldn't make it to the Salute, here are the rules and stats of the new faction, the Hord.
It will be released with the others news at the beginning of May ![]() New rules Frenzy tokens (symbol : ☬) Each time an opponent fighter is removed from the field because of wounds caused by an allied fighter, you gain ☬. If the value of the removed fighter is higher than or equal to 25, you gain ☬☬ instead. If the value of the removed fighter is higher than or equal to 40, you gain ☬☬☬ instead. The token(s) are placed on the card of the nearest allied Dominant fighter, within 20cm of the location of the removed fighter. - An allied fighter can only use his Savagery special ability if he is within 20cm of an allied Dominant fighter unless he is himself of Dominant type. - When an allied fighter uses his Savagery special ability, the tokens he spends are withdrawn from a Dominant allied fighter (or his own card if he is of Dominant type) within 20cm. - The Savagery special ability is usually composed of multiple sub-effects, each one with a ☬ activation cost. Each sub-effect can only be used once a round. Dominants When you create your troop of Horde faction, you have to recruit at least one Dominant fighter. Moreover, you troop leader must be of Dominant type. When a Dominant fighter is removed from the filed, all ☬ tokens placed on his card are lost unless they are immediately spend. Brood Master (Mutant, Dominant, 25 points) (30 mm) - HOR-001 ![]() PSI - 3/2 - ◯◯◯◯◯ - 1 CBT - 5/3 - ◯◯◯◯◯ - 2,3 VIG - 4/3 - ◯◯◯◯◯ - 4,5 SPD - 5/4 - ◯◯◯◯◯ - 6 No equipment. Mind control (perm) At the beginning of the intendancy phase, place ☬☬ on the Brood Master card. Improvisation (Action, 1/match) During the activation phase of this round, your opponent cannot pass the hand. Wild scream (action) (☬, 1/match) All opponent fighters within 7.5cm from the Brood Master perform a PSI roll with a difficulty level of 5. Those who fail to pass this test receive a Fear marker. Synchronization (action) (3SP, 1/match) Just after the Brood Master’s activation, immediately activate (in the order you choose) all allied fighters of Degenerate type. Your opponent cannot interrupt the activation of these fighters. Beastmaster (Mutant, Dominant, Tamer, 20 points) (30 mm) - HOR-002 ![]() PSI - 4/3 - ◯◯◯◯ - 1 CBT - 4/3 - ◯◯◯◯◯ - 2,3 VIG - 4/3 - ◯◯◯◯◯ - 4,5 SPD - 6/4 - ◯◯◯◯ - 6 No equipment. Mind control (perm) At the beginning of the intendancy phase, place ☬☬ on the Beastmaster card. Trainer (action) (☬, 1/round) Designate an allied fighter of the Minion type, which is not activated yet and is located 15 cm or less far from the Beastmaster. Choose one of the following: - This fighter performs immediately a free action of your choice. Nevertheless, he is not considered as having been activated and the action he performs must respect all its inherent restrictions. - Remove a Fear marker or a Rage marker from this allied fighter. Enragement (action) (☬☬, 1/round) An allied fighter within 10cm from the Beastmaster gains a rage marker. Degenerate (Mutant, Degenerate, 15 points) (30 mm) - HOR-005 PSI - 1/1 - ◯◯◯◯ - 1 CBT - 4/2 - ◯◯◯◯◯ - 2,3 VIG - 5 - ◯◯◯◯◯ - 4,5 SPD - 3/2 - ◯◯◯◯◯ - 6 No equipment. Mutant metabolism (perm) At the beginning of the intendancy phase, choose and heal one CP on one of the Degenerate's limbs. Apathietic (perm) At the beginning of the round, before choosing the First Player, the Degenerate loses 1 AP. Savagery (perm) - ☬ : the Degenerate gets 1 AP. - ☬ : the Degenerate gets a +1CBT bonus until the end of the round. - ☬☬ : the Degenerate gets a +1CBT bonus until the end of the round. - ☬ : the Degenerate gets a +1SPD bonus until the end of the round. Starving degenerate (Mutant, Degenerate, 15 points) (30 mm) - HOR-004 PSI - 1/1 - ◯◯◯◯ - 1 CBT - 4/3 - ◯◯◯◯◯ - 2,3 VIG - 4/3 - ◯◯◯◯◯ - 4,5 RAP - 4/2 - ◯◯◯◯◯ - 6 No equipment. Cannibal (perm) This ability has no effect if the Starving degenerate has no wounds. Each time the Starving degenerate inflicts at least one wound to a fighter because of a close combat attack, he is healed of one CP in a limb of your choice. Starving (perm) The Starving degenerate gets a +1 CBT bonus for each other Degenerate type fighter in contact with the target of his CBT roll. Apathietic (perm) At the beginning of the round, before choosing the First Player, the Starving degenerate loses 1 AP. Savagery (perm) - ☬ : the Starving degenerate gets 1 AP. - ☬ : the Starving degenerate gets a +1CBT bonus until the end of the round. - ☬☬ : the Starving degenerate gets a +1CBT bonus until the end of the round. - ☬ : the Starving degenerate gets a +1SPD bonus until the end of the round. Bloody degenerate (Mutant, Degenerate, 25 points) (30 mm) - HOR-003 PSI - 2/1 - ◯◯◯◯◯ - 1 CBT - 5/4 - ◯◯◯◯◯ - 2,3 VIG - 5 - ◯◯◯◯◯◯ - 4,5 SPD - 4/2 - ◯◯◯◯◯ - 6 No equipment. Mutant metabolism (perm) At the beginning of the intendancy phase, choose and heal one CP on one of the Bloody degenerate's limbs. Starving (perm) The Bloody degenerate gets a +1 CBT bonus for each other Degenerate type fighter in contact with the target of his CBT roll. Call to death (perm) When the Bloody degenerate is removed from the field, place ☬☬ on the card of an allied Dominant fighter located within 20cm from the location of the Bloody degenerate. Savagery (perm) - ☬☬☬ : the Bloody degenerate gets 1 AP. - ☬ : the Bloody degenerate gets a +1CBT bonus until the end of the round. - ☬ : the Bloody degenerate gets a +1SPD bonus until the end of the round. Lycal (Minion, 5 points) - HOR-006 - HOR-007 - HOR-008 PSI - 1/1 - ◯◯◯◯ - 1 CBT - 3/2 - ◯◯◯◯ - 2 VIG - 4/3 - ◯◯◯◯◯ - 3, 4, 5 SPD - 5/4 - ◯◯◯◯ - 6 No equipment. Pack (perm) You can recruit up to 3 Lycals in your troop if a Tamer fighter is also recruited in your troop. Savagery (perm) - ☬ : the Lycal gets a +1CBT bonus until the end of the round. Narrow-minded (perm) The lycal is not taken into account for the achieving of the Mission of the troop in which he is recruited. He ignores all restrictions and/or special rules of this Mission and he is ignored for the counting of the VP of this Mission. Nevertheless, he is normally taken into account for the opponent Mission. Chitinous Hound (Minion, 10 points) - HOR-009 PSI - 1/1 - ◯◯◯ - 1 CBT - 4/2 - ◯◯◯◯ - 2/3 VIG - 4/3 - ◯◯◯◯◯ -4/5 SPD - 4/2 - ◯◯◯◯ - 6 Equipment: Chitin (Pr): Head+1, Torso+1. Savagery (perm) - ☬☬ : the Chitinous Hound gets 1AP. - ☬ : the Chitinous Hound gets a +1CBT bonus until the end of the round. Mireling (Mutant, Minion, 15 points) - HOR-010 PSI - 2/1 - ◯◯◯◯ - 1 CBT - 4/3 - ◯◯◯◯◯ - 2/3 VIG - 4/3 - ◯◯◯◯◯ - 4/5 SPD - 3/2 - ◯◯◯◯◯ - 6 No equipment. Poisoning (perm) When a fighter loses at least 1CP because of an attack of the Mireling, he gets a Poison marker. Savagery (perm) - ☬ : the Mireling gets a +1CBT bonus until the end of the round. - ☬ : the Mireling gets a +1SPD bonus until the end of the round. - ☬ : the Mireling gets a +1PSI bonus until the end of the round. Poisoned Epidermis (perm) When the Mireling loses at least 1CP because of an attack action, a response or special ability, all fighters in contact with him receive a Poison marker. Missions The scavengers (Horde) Revealed mission - Ambush deploiment When an opponent fighter is incapacitated, replace him with a Dead Body marker, the size of his base. All allied fighters get the following special ability: Devouring (action) (1 AP, 1/round) If the fighter is free and in contact with a Dead Body marker, he gains Hunger marker. At the end of the match, each allied fighter still on the gaming field earns you VP equal to his value multiplied by the number of Hunger markers he has. Reminder: Any number multiplied by zero gives zero. Unexpected (Horde) Revealed mission - Ambush deploiment You cannot play this mission if your opponent chooses his mission card before you. After having chosen this mission, your opponent must choose a Revealed mission. Your opponent plays the end of the Preparation phase as usual. At the beginning of the first round, your mission is then equivalent to your opponent’s. Tactical cards Blood lust Place ☬☬ on the card of an allied Dominant fighter. Shared ferocity Transfer as much ☬ as you wish from one allied Dominant fighter card to another allied Dominant fighter card. ![]() |
04-25-2012, 08:47 PM
RE: The Hord
Added some pics
04-26-2012, 09:03 AM
RE: The Hord
Thanks Berf. Models look fantastic.
My gaming blog |
04-26-2012, 06:57 PM
RE: The Hord
Broodmaster is indeed a tad gruesome for my taste (what is he doing with that poor torso?) but the Beastmaster looks great. I especially like the ravens - a great touch IMO.
Resistance is non-futile. |
04-28-2012, 02:50 AM
RE: The Hord
I'm a big fan of these guys, always wanted to run a horde of fierce beasts and this is such a good way on fitting them into the game as a playable faction. Also, the Brood Master has rocketed to my top-spot for favourite Eden model
![]() Will the other fierce beasts that do not have a 'minion' card be getting them? Most importantly the Dominant Lycal! Hopefully he'll count as 'dominant' in regard to other lycals too? I like Lycals ![]() |
04-29-2013, 07:21 AM
(This post was last modified: 04-29-2013 07:44 AM by Vargas.)
Post: #6
RE: The Hord
Hi Berf
I just picked the Broodmaster starter and Flesh master up at Salute and am very happy with my purchase so far. Two questions for you: 1. Are there other mission and tactic cards to use other than the ones you describe above? They seem fairly limited compared to the other factions. Are there genecric mission & tactical cards to use as well as them? 2. Does the Flesh master's ability to cancel out SP effects on Hord models also cancel out the Brood master's too? ...oh and...the Scavenger mission...how many times can a fighter devour a single Dead Body Marker? Does it increase with the base size? |
04-30-2013, 05:51 AM
Post: #7
RE: The Hord
Welcome to the wonderful world of the Hord!
1. You can use all mission and tactic cards that don't specifically have a symbol of a different faction. So yeah, feel free to use the generic ones. 2. I believe so, yes. Flesh Master is in that regard a bit of a two-edged sword. Resistance is non-futile. |
05-06-2013, 05:26 AM
Post: #8
RE: The Hord
Thanks for that. Any thoughts on the scavenger mission?
05-07-2013, 05:37 AM
Post: #9
RE: The Hord
(05-06-2013 05:26 AM)Vargas Wrote: Thanks for that. Any thoughts on the scavenger mission?Ah, missed that one. The way I read it, you can eat from a dead body as many times as you like with as many models as you like (though only once per round per model, naturally). Resistance is non-futile. |
User(s) browsing this thread: 2 Guest(s)
