Rogue Paladine Translation?
12-07-2011, 10:40 AM
Hey all, just found out I'm getting this Rogue Paladine chick in a trade. Is her card available in English?
12-13-2011, 06:33 AM
| RE: Rogue Paladine Translation? | |||
12-14-2011, 09:38 PM
(This post was last modified: 12-14-2011 09:44 PM by Berf.)
Strange, I was sure the english card was downloadable.
Here it is anyway : Stats, self-explanatory ![]() Equipment : Shoulder-pad (Pr) : Arm +1 Abilities : Mercenary (permanent) A fighter with this ability has no Faction symbol. This alows her to ignore the Faction type restriction when creating your troop and therefore include her in any Faction type troop (however she is not considered to be part of the Faction in which she is recruited for any other game effects. Note : this applies to abilities targeting specific Factions, Tactical cards for specific Factions and restricted Missions, for example if you play Alisha with the Jokers, she cannot collect the Stuff or Plunder). If she is recruited in a Faction type troop, her PSI is divided by 2 when calculating the reserve of SP. Crusade's Minion (permanent) If Alisha is recruited in your troop, you can also recruit any Slave type fighter with a Value of 10 or less. You can ignore any Faction or Stigma restrictions when recruiting this Slave. Faith of the Crusaders (permanent, 3 SP) You can activate this ability when Alisha suffers wounds that should Incapacitate her. Cancel all these wounds. In return, select a "normal" limb and check all the remaining white CP of this limb. You cannot use this ability if all of Alisha's limbs are "wounded". Solitary crusade (permanent) Alisha gets a +1 CBT bonus when she is at 20cm or more from any allied fighter. |
12-15-2011, 01:12 AM
Sweet! Cheers Berf!
12-16-2011, 05:21 AM
Nice one Berf, might be getting one of these in a trade myself
User(s) browsing this thread: 2 Guest(s)
